squeaky belts?
glanga
Beverly Hills
just wondering since i searched and didnt find anything, since ive owned the car (03 ls v8 prem sport) there is a sort of belt squeak not too loud but its definentely noticeable until the engine warms up and sometimes a little after it warms up but usually only at lower rpm's. if it is or has recently rained or is humid it squeaks through the entire rpm range getting louder the higher the rpm. my mechanic buddy at a ford dealer listened to it, checked it out and replaced whatever it was or fixed it. but it came back no less than 2 weeks later. anyone have this problem, know what its caused by, or what it is in general and how i can get rid of it for good? thanks -greg
My 06 LS does that....same circumstances as described by you. I tend to notice it more on humid days, though. Am going to have it checked out at its 15k service.
Mine does the same thing. I had them look at it last time I was in (wasnt doing it then) and they said there is nothing wrong with it. However when it was squeaking the other day, and I looked at it, the belt was moving side to side. When it was squeaking it was rubbing on the side.
yea just go ahead and get a half of inch belt and it should solve the problem. i had a new alt installed with a lower pulley, and it started shrinking with my original belt so i shrunk my belt down and it solved the problem.
The LS has a really long serpentine belt and it goes thru lot of pulleys. My GUESS is that this is just the nature of the beast and some will squeek no matter what.
Experience with other cars is that you can do some things to help.
A new belt often does the trick. Another car group had good experience, including me with the Good Year Gatorback belts. Don't know if there is one for the LS. They are a bit more expensive but they don't squeek. If anything they have kind of a supercharger whine to them but very faint.
Clean pulleys and belt. I sometimes will clean all the pulleys with alcohol or brake cleaner. DO NOT use anything that has oil in it like petroleum solvents. DO NOT use belt dressing, it seems these really gum up serpentine belts.
Sometimes I rough up the pulley surfaces with some coarse sand paper.
You can sometimes clean the belt enough to stop squeeking. Use rubbing alcohol or similar. I think Brake Cleaner is not good on rubber so I don't use that. DO NOT use petroleum solvent. If the belt is shiney, ie glazed, then you are probably doomed and need a new one.
Sometimes it isn't the belt, it is a bearing in one of the pulleys. This can get expensive since Ford seems to like to use non standard bearings so you have to buy a whole assembly including mounting arm sometimes. This happens even on lowly common as dirt Tauruses, lord knows how special our LS pulleys might be.
Just my experiences with other cars, my LS doesn't squeek so far.
Jim Henderson
alright, well thanks ill ask tell them to get find out and post what i found, its going in thursday for service
