To answer jcavz24x question quickly there the dash kits only come in that style as far as i know. And i have only seen them in Black and Silver. And HUs are so hard to recommend. Some people prefer dolphins and racecars being displayed on their units and some people prefer 4v preoutputs. Only you can some but some good brands to consider are Pioneer, Eclipse, Alpine, Kenwood, and JVC. A mobile audio rule of thumb is, you get what you pay for. With the exception of Sony and JL. Also newer models are good for people like you because when they are released the old new modles drop in price.
kleetus,
The numbers i used i pulled out of my a$$ as an example. i am talkin bels which is a compairison between two powers. To actiallyl figure out how much strain is put on the battery depends on many factors. For one you need to know what the current drain of the amp is, which would be the deciding factor on how efficient the amp is. But one big thing to consider is that every amp operates on a wide range, meaning it all depends on how loud you play it
. But assuming the maximum....
As far as car batteries are concerned...
batteries are rated by amp-hours. your amplifier draws so much power (Voltage * Current). Power is measured in watts, however we can use amps to measure power with an assumed voltage of 12V. ie, P/12V = amps
kinda funny how they measure power in amps even though it's really watts, but go figure
so in any case, a 12 amp hour battery can supply 12 watts for an hour, or 6 watts for 2 hours, or 3 watts for 4 hours, ect.
We will use this amp as an example...
http://jlaudio.com/amps/5001.html
now assuming your amp runs on 12V, you measure the current that your car amp draws, and the amp-hour rating on the battery tells you how many hours the battery can supply that amount of current
lets assume the amt of power driven to the speakers is the power consumed by the amplifier, big simplification, I know.
I think 500 W rms would be 250 W DC. 250 W / 12V = 2A. lets say the battery is 450 amp-hours. 450 / 2 = ~22.5 hours
That's how long the amp would work straight off the battery assuming battery is fully charged...
Also this is all assuming perfect power transfer, my conversion to DC watts was correct, and that the max power output listed is the amount of power drained by the amp.
Ok lets use my amp as an example... Its a mark antony 3000D that is rated to output 3kW at 2 ohms.. It ran for about 10-15 mins before it drained the battery...
3000 W / 12 V = 250 amps
450 Amp-hours / 250 amps = ~2 hour
now lets calculate how many amp-hours my battery is if it only gets 10-15 mins...
15 mins ~ 0.25 hrs
so x amp-hours / 250 amps ~= 0.25 hrs
x = 62.5 amp hours
also, this is only a first order approximation of battery life. the rate of discharge is also a factor, ie, discharge a battery quickly, get a shorter lifespan... or some other non-linear fun... Wow my battery sucks lol.
But also a headunit was running and whatever else drains power then the ignition key is on... here are some facts...
headlights 10-15 A
parking lights 3-5 A
interior light 1-2 A
radio 1.5 A
air conditioner 15-30 A
Now on a charging system.. Is and amp is putting out 200 W to the speaker, nothing can change that... but the amount of power they use internally is greater, ie, you lose power simply by the act of amplification. that's one reason amplifiers generate heat, heat is energy lost, and therefore power lost. a more efficient amplifier will lose less power internally. It's like machines... they can give you mechanical advantage and make lifting heavy objects with one hand a breeze, but they also consume more energy via frictional losses. Many things to consider here... So if you see an amp with internal cooling fans, then its probably not power efficient, safe and probably has a nice DB ratio but still not very efficient.
Sorry for suck a long post i tried to touch on a lot of bases.
