Steering column replacement
414Boy
Milwaukee
I just finished replacing my steering column. I need to replace the plastic peices that go around the column, but I need to know how to take the black part of the switch off to do so.
at the bottom of the switch housing is a small hole,you need to insert a coat hanger size screw driver or something else in there of that size to release the ignition switch,it will then pull out the whole ign cylinder.
Worked out thanks.
