Steering Wheel has a mind of its own...
itsnotmydaddys
Saint Louis
I have my wheel programmed to how i like it. Im 6'5 so i need to sit far back and the wheel needs to be all the way out. but lately the wheel will just program itself to any spot. usually its in all the way and crushing my knees. What causes this. How can i fix it. Does anyone else have this problem
well im thinking its a malfunction of the memory and since a default is set for anything thats customizable maybe its going back to the default setting cause its not remembering your settings.
I have an 03 V8 Sport that does the exact same thing.
It's about 50/50 that it will go to the correct programmed location, otherwise, it will drop all the way to the lowest postion.
When you press the memory button, it then goes to the correct location, so it hasn't forgot the correct location, just a brief lapse of memory...
I do this also because mine tends to forget
