free139stylz
Hey guys my stock head unit wont come on but when I press set time button the time comes up so that mean its definitly not my fuse rite??? anyone know what the problem might be
free139stylz said:yea sport your rite because when i take the radio fuse out the time still comes on!!!!which other fuse do you think it would be?? one under the hood
pdzcallday said:there is like 5 or 6 fuses just for the radio. take a DMM and test every fues. The fuse location my not say radio but it has something to do w/ the radio. Had this problem my self. swiched my radio out an some how poped a fuse. Replaced all fueses and radio still did not work. Took a DMM and tested all fuses and found one that had nothing to do w/ the radio replaced it and it works just fine.
Sounds like a grounding issue...........if you shut your car off and have the radio on and everything is normal, a bad ground connection would be the first thing I would assume.pbslmo said:hey guys,
Anyone help me with getting rid of the feedback noise, or engine noise in the speakers? Sometimes it just starts doing this when I hit a bump and then somtimes it goes away by itself. It is really annoying. When I turn off the stereo it last for a couple of second and goes away. When the car is shut off and the stereo is on the noise is gone, so something is either shorting or something.
rickster said:Same thing happened to me and it was the fuse.the one on the pasenger floor.Does your radio still accept cd's?
