I need a new steering column for my 1998 Lincoln mark viii lsc. I severely need any help and advice and knowledge on the matter of getting mine fixed or replaced.
Other than looking at your local junkyards like Pick n Pull or U-Pull It, your best bet would be to look online like ebay or car-part.com for the steering column. I remember there being talk that the column was interchangable with another one of Ford's vehicles, maybe Continental, but can't say for sure.
Hi My tilt/telescopic wheel has always worked flawlessly. My M8 has been sitting for a bit as I source an ABS pump. now the tilt works fine but it doesn't move out. It seems like it went in too far as the signal switch is now tight against the dash. I found the following threads, I already tried...
www.lincolnvscadillac.com
Someone even posted a video on Youtube
One of my Marks has this same issue but it was never too big a deal for me to fix. Although, it is also the one with Air Bag Code 32 - Clock Spring.
I've attached several PDFs of the Steering Column section from the Mark VIII CD Workshop Manual. I merged them together to upload as 1 file but it was too big.
Mark VIII Steering Column Dis & Ass.pdf
809.3 KB
Mark VIII Steering Column Tilt Tele Motors R&I.pdf
