topher5150
I posted this before but i'm still trying to get rid of this stuff
make a decent offer the engine had 130,000 miles
left cylinder head
right cylinder head
2 intake manifolds upper and lower
fuel rail
1 throttle bodies with throttle position sensors
left exhaust manifold with O2 sensor
right exhaust manifold with O2 sensor
fly wheel
crank shaft
EGR tube
2 EGR
cooling tubes (tubes which run under the intake to back of cylinder head)
2 crank and water pump pullies sold as a set
pair of motor mounts
timing chain tensioners
idle air control
oil pick up tube
power steering resivor bracket
complete fuel injection wiring harness
water pump
emission tube and valve and bracket (the one that runs in front of the engine to the cats)
timing chain cover
oil filter bracket with oil pressure sensor
air filter box with K&N air filter
MAF housing
left cylinder head
right cylinder head
fuel rail
fly wheel
crank shaft
EGR tube
2 EGR
idle air control
oil pick up tube
water pump
timing chain cover
MAF housing
