stock or aftermarket deck???
LSV84U2NV
Toronto
if i'm going to put a system in i know there will be a sound difference if i put an aftermarket deck in but will it be that much difference or is it better just to keep the stock deck with the line out conv???
Go with the aftermarket deck. you have have more control of the sq you can get from the subs and from the mid range and high speakers. You will also have to work the amp for the sub less as it is not tying to amp a low volt.
I noticed aa big difference when I swapped the HU. More control, plus better output and quality.
