stoopid laptop
topher5150
Grand Rapids, Michigan
the screen on my laptop keeps flickering, it doesn't cut out, the bottom 75% turns cloudy, when i tap the side of the screen, or adjust the screen it goes away for awhile. I'm pretty sure it has the something to do with the connection at the hinge, is there any to fix this?
call them and tell them that you need the part number for the cable that goes between the lcd display and the motherboard. They are probably gonna tell you that it comes as part of the LCD, so you may have to buy that. You can find used ones on fleabay for cheap.
