Straight line performance tire
Dern Humpus
Warrensburg, MO
I am currently running an 80 shot off the line, with stock 3.08 gears and obviously am having a little trouble hooking up, however the spin isnt horrible. I feel with a little bit better tire than the POS's I have on there now it will rocket out of the hole. Can anyone suggest something for a stock wheel that will hook awesome that I can drive in snow a bit with? Also can I fit a larger tire size on the stock wheel or should I keep with the 225's?
Buy an extra set of wheels and get some drag radials. Bolt them on for when you want to go to the track. Get tires that match the fronts so you don't have ABS issues.
