Strange stuff
KC96LSC
Kansas City
I was driving home last night and the car started cutting out. Almost like it was running out of gas. it got worse as I went on tell finally I had to pull over. Dark smoke started coming out from under the hood. It was so bad I thought it might start on fire so I didn't want to open the hood. I'm not sure but it looked like it was also coming out of the exhaust tried to start it a couple times and it sounded like the engine was coming apart. Like a bad rod banging around in it. Started calling for a tow, sitting on the side of the highway at night with cars and semi's going by at 80+ lots of fun for sure.
Anyway couldn't get anyone to answer their phone. So I tried to start it again (the 10th time) and it started. It was a bit rough but I went about a mile and it started to miss again. Polled over and waited a few minutes and started it back up. Went slow at first then it was running OK (felt like it was missing a bit) but it keep going. stopped and got gas and lift the hood. As normal couldn't see anything. Now it was running OK and got it home. while coming back home I punched it and it ran like normal, any Ideas?
Thanks for any advice.
Greg
fuel injectors plugs and wires. check your maf and cell also. check your oil see what it looks like also. if it looks like a milkshake ur screwed.
Already checked the oil. That was the first thing I did. It fine But thanks for the input. anyone else?
Do you have a chip by any chance? My car was stalling out/cutting out on me because the chip got loose.
sounds to me like you had a wire short out. In order for you to see smoke coming out from under the hood there has to be a lot of smoke. You would only see dark smoke out of your exhaust if it was missing or if it was internal to the engine. I would search around for a burnt wire. It probably act as a fuse, shorted out, got hot, burned the insulation off (smoke) and then fell apart.
:I :wrench
