sprocket
Well, the D.A. has a new issue now. A little background info:
This car had/has a head gasket issue but since using Blue Devil it has passed the hydrocarbon test three separate times including very recently.
I also replaced the fuel injectors but got maybe too good of a deal off eBay. I suspect some of them leak. The car started very hard in the winter unless I put the pedal to the floor first to prevent fuel flow for several seconds. Then it would start right up. It starts OK in the summer but I suppose the fuel atomizes easier now.
OK now to the problem: I'm getting a stumble under light acceleration and I think it might be tied to RPM more than MPH. If I give it more gas it will take off. It never stumbles on the highway at constant speed, but if I let off the gas and coast, then when I give it throttle again it might stumble.
My list of suspects would include:
1) Dirty MAF (but I think I recently cleaned it)
2) Dirty IAC (the idle isn't the smoothest on this car either)
3) TPS dead spot
4) Something in the shifting. 2-3 accumulator?
5) The cheap injectors
Anybody have any advice on isolating the problem? I'm thinking it very well could be the 2-3 accumulator. I suppose I should try driving with the OD off?
3) TPS dead spot
