Subwoofer Help..
lexdiamondz10304
Palmdale CA :(
Ok, I installed a infinity 10" reference 1032 subwoofer powered by a 500rms watt mono swiss audio amp, and the sub is producing voice, is this normal?, I also tried the sub with my friends performance teknique amp and it still produces voice, any ideas?
Wiring probably. Check to make sure you didn't hook the RCAs into the high level outputs. Or if you have only one output, make sure the low pass filter is on.
you might also want to check at what Hrtz your amp is cutting your sub at. Too high a Hrtz and you may get some voice. A ten inch sub should be cut at around 120 to 80 Hrtz. Any higher you will get some mid-range sound, any lower the 10" sub can't reach effectively.
