Sunroof has no power?
Ace
Stroudsburg
Ok so when I was going down to Carlisle this weekend and my car has a slight driveshaft vibration at 70-75 mph which is no big deal but it makes enough to rattle the sunroof a little bit. My cunerman side came out and I slid a pack of matches in from the inside and the little clatter went away.
Today, I go to open the sunroof and It will not open. Check the windows first and see that they go up and down so figure fuse is good. Check fuse anyways and is good.
I took down the switch and I have no power at the switch, do you think by some miracle that I broke a wire going from said fusebox to the switch? thanks for the help in advance!
I have the same issue its like it only works when it wants to, but it never worked when I had a issue with my fuse box also on left turns that i take sharp my radio cuts out I'm guessing either a wire or fuse box issue messing with both.
One question does it open in vent, but not all the way?
take off the negative off the battery for 20 secs and put it back on, whenever i do this i always hear the relays for the roof start clickin, so maybe its stuck or something? give it a shot. maybe the relay is stuck in the wrong position and not allowing the power to get to the motor.
If you have that ASC sunroof, they like to patch that into the DS fuse panel with a couple of wires. A rough road will loosen them.
