Hey guys i have a problem with my sunroof the motor works but the switch have no power and the fuses are good so what can you guys suggest me to do before i go to the next step. Thanks in advance, lsc2dabone
Electrical diagnosis is handled in a flow like process. start at the power source and continue component by component, wire by wire, downstream, until you reach the part that has no power, but is supposed to. a good wiring diagram is helpful too. BTW, you have a switch and a motor. Do you have a relay in that circuit?
