Superchargers, Fabrication, and Ideas (worth the read)
ZacUnknown69
Minnesota
So - I keep thinking how expensive it'd be to install a supercharger to my Mark. I was looking on eBay and dreaming about getting one - but I had an idea. The Eaton M90 is smaller than the M112 and can handle up to a 6.0L V8. As far as size, I could even get an AMR500. So I came up with an idea, you tell me if it's possible;
First, buy a smaller supercharger, then purchase a second upper intake manifold from a Mark, Mustang, or Crown Vic if it fits. Then plasma cut the manifold to the measurements to the bottom of the supercharger. Either weld that S.O.B onto the manifold or if possible have a gasket made and bolt it down. Once that's done, remounting things as well other various modifications that need to be done. Give it a tune and then..bam - supercharger. I don't believe it'd run high PSI's - I estimate, 4-9psi. But regardless - I've done some research on the cost of fabricating what I need and it's not all that expensive. The 3 main things; supercharger, manifold, fabrications, would only cost about $500. So - is this possible? Or am I dreaming?
You keep trying to find a inexpensive way to install a supercharger on your Mark VIII. Through all of this you have demonstrated to have little or no knowledge about these cars or superchargers. Yet you ignore people who know these cars and superchargers telling you over and over there is no cheap way to supercharge a Mark VIII ???
