suspension help!!!!!!!
br94mk8
Portsmouth,RI
I have a 1994 lincoln Mark VIII the suspension wont pump up I put a brand new compresser and drier in and still nothing I get a check suspension message as soon as i turn the key so I need what ever it is keeping me grounded.any ideas and if so do you have the part.
any help would be really helpful im stuck for now
The module does a quick once over of the system on startup. If it "see's" something out of range, it doesn't know what to do. This could be a relay, sensor or even in the wiring. If your getting a check suspension message as soon as you crank the car, the module is detecting a problem in the system somewhere.
To get going again, your going to need to pull the code(s) to know where to start. If you would like, I can send you a loaner Star Tester to get the code(s). Just let me know.
