MarkVIII93
Will rear t-bird springs work in the rear of our cars with no problems?
This is what I am wondering. If you look at some of the conversion kits, it looks like the top mount is a flat piece of metal with the corners bent over, and a stud to position it. If the T-Bird springs are the same, it should be easy to make.MarkVIII93 said:So, would it be possible for me to fabricate some of my own spring adapters?
Anyone know?my95mark8 said:This is what I am wondering. If you look at some of the conversion kits, it looks like the top mount is a flat piece of metal with the corners bent over, and a stud to position it. If the T-Bird springs are the same, it should be easy to make.
