lexdiamondz10304
I had to replace the pass. side brake light bulb, but as I took it out the plastic harness were the bulb is mounted crumbled since it was dry rotted from the heat of the bulb, anyways I went to autozone and bout a new harness for the light, I cut the old one off, and wired the new one in, and it works fine, but when I turn on my headlights and I push the pedal the check bulb light turns on the dash, and goes off when I let go of the brake pedal, so I step on the brake, check bulb light turns on, I let go, and it comes off. Any ideas?
