Taking off interior pannels
MrWilson
NJ
Those who have done it...where do i start? any special clips or something of the like i should be worried about?
The doors are mostly screwed on and hung. Don't pry them off.
MrWilson said:
door, rear side, all of em.
Doors:
(Gently pry)
Remove the handle cover- 8mm bolt.
Remove the window switch cover- unscrew from harness.
Remove door/ seat memory, side mirror trim- pry off the harnesses.
Remove the bottom reflector- remove phillips screw.
Remove side mirror cover- push in, pull up.
Pull up on the door panel, disconnect the additional harnesses.
http://www.lincolnsonline.com/tech/00055.html
The rest:
Pretty much just basic screwdrivers. The seatbelts are torx.
