temp gauge question
98LSC32V
Bay Area
What temp is the engine at when the needle is at the far lower part of the Normal range?
you got a 180 tstat, so watch your gauge climb and when it starts falling i guess its at 180 or your fan kicked on
Actually right now i'm running with no thermostat at all...
is that ok? cuz i was thinking of doing that.
Yea the engine runs really cool all the time. It takes longer to warm up but since I have a manual fan switch I just don't turn on the fan for a while.
is that why a 160deg t-stat is good?
I have researched this and was told this...
N
-240
O
R
-225
M
A
-185
L
I have recorded this...
| N-
| O-
| R-215
| M-205
| A_180
| L
|---160
This is probably valid only for Gen1s as I have heard the Gen2s are different.
The fan normally turns on at 215* and turns off at 205*(without AC).
Anywhere from 160 to 180 degrees is the perfect operating temp. for a fuel injected engine.
I have a bypass circuit for the cooling fan I use at the track. I 'upgraded' it by adding a programmable controller so I wouldn't have to manually turn the fan on and off. I set the ON temp to 180* and the OFF temp to 165*. I have a 160* T-stat. :D
where would i get a 160-tstat?
