AmsterDutch
SECTION 303-03: Engine Cooling 2001 Lincoln LS Workshop Manual General Specifications Item Specification
3.9L 11.3 3.0L 10.6 Cooling fan MAX speed 2,300 ± 100 rpm
Cooling fan MAX pressure output 1,200 psi
Cooling fan operating pressure 900 psi
Cooling fan operating flow rate 4.0 ± 0.25 gpm
Coolant mixture with water 50%
a Pressure relief cap opening pressure kPa (psi) 110 (16)
Water thermostat start to open temperature 87-93°C (192-199°F)
Water thermostat full open temperature 104° C(219°F)
Lubrication Premium Cooling System Flush F1AZ-19A503-A ESR-M14P7-A
Premium Long Life Grease XG-1-C ESA-M1C75-B
