The Flying Car....
Specifications
General
- Drives and Flies like a Car with Integrated Controls
- Drive System: Dual-drive (Transaxle or Propeller)
- Fuel Capacity: ~15 gallons
- Engine: Subaru 2.5L 170 hp Fuel Injected and Water Cooled (standard)
- Frame: Welded 4130 Chromoly with Powder Coat Finish
- Suspension: Long Throw Suspension with High-Performance (Fox Float) Shocks
- Wheels & Rims: Low pressure knobby tires on 12" aluminum rims (standard)
note: Maximum off-road performance with limited upper end speed
- Seats: 2-place Tandem Seating with 4-point Harnesses
- Body Cover: Removable Marine Grade Sunbrella "Tuxedo" with Crystal Clear vinyl sheet windows (color choices available)
- Instrumentation: Ground/air GPS, engine monitor and Intercom (standard)
- Conversion Time: 5-10 Minutes between Drive and Fly modes
- Options:
- Engine: 2.5L Fuel Injected w/ Turbo (request availability)
- Wheels & Rims: High speed road tires with 15" aluminum rims (15x4 front - 15x6 rear)
- Instrumentation: portable COM radio or panel-mounted flip-flop COM radio
- Fenders
Aircraft Specifications
- Gross Weight: 1,320 Lbs
- Empty Weight: 987 Lbs (standard)
- Airspeed: ~40 mph
- Climb Rate: 600 fpm (sea level at gross weight)
- Endurance: 2.5 hours
- Takeoff Distance: <300 ft
- Landing Distance: <250 ft
- Service Ceiling: 10,000 ft (limited by LSA regulations)
- Propeller: Powerfin or Warp Drive
- Capable of taking off and landing with a crosswind due to Wing Deployment System
Car Specifications
- Road Legal (kit car)
- Transmission: Continuously Variable (CVT)
- 0 - 60 mph: ~3.9 sec
- Fuel Economy: ~25 mpg (highway)
- Lights: Headlights, Brake Lights and Turn Signals (standard)
