Can i use a thicker oil in my 103,000 96 Gen 1 to quiet the sometimes clicky valvetrain down. Wouldnt it provide lost pressure from wear and help to prevent bearing failure? It is garage kept but i live in Michigan.
Any thoughts??
Thanx, John
Any thoughts??
Thanx, John
I run the LUCAS 5-20 full synth and love it I'm taking samples to compare to the mobile 1 I sample I have on the shelf. I know it's not necessary but I'm just courteous as to what the differences between the 2 will be.
I use Mobile-1 Full Synthetic 5W-20. I hear good things about Lucas
and Royal Purple too. I use to use Castrol until I found out they were
owned by BP* British Petrolium.
Thinner oil will cause less wear and tear to an engine at start-up where
90% of wear happens.
My engine is not as noisy at start-up after I made the switch to the thinner
oil. I also noticed lower engine temp on my regular commute.
Ren
is it true that you should use a thinner oil in the winter time?
