Thinking about lowering my ls
YoungLs1996
edgewood
Just started to think about lowering my 2002 lincoln ls, I just wanted opinions from people, and what brand of springs should I look into. Any help would be nice
I've had eibachs and GR+'s. Both have pro's and con's. Depending on mileage and wear and tear it might be more cost effective to get the coilovers and then just pretend like you just bought new shocks and springs leaving them dialed in where you want them.
Did you order yours from TF-Works? Did you ever get those bottom mounts figured out? This might be worth noting if Stance did not rebore out those and some are still floating around with the improper specs
Yeah from TF-Works. The rear bottom mounting holes were too small. I talked to Stance and they offered to send me new bottoms but I didn't want to wait. I bored them out on my dads milling machine.
Good deal. The specs were off when they went to production. My hope was that they were going to correct all the ones that were sitting around. Guess that never happened. They were off by 1mm.
Rod ordered two weeks after I did. His were undersized but mine were corrected, weird
