Throttle Body & Intake
performance upgrade
  • what type of throttle body do you perfer
    Votes: 2 66.7%
  • what type of air intake tubing do you have
    Votes: 3 100.0%
  • Total voters
    3
  • Poll closed .
Ervinlee
Los Angeles
I was woundering if there is any type of tubing that i can use non metal to complete my air intake system, Also have any one change there throttle body and the throttle body elbow
if you are refering to the intake air tube. Then there are some great platics out on the market that are very heat resilient. I have been planning on building on for my V6. Just have not had the time to tool around with that project yet.
plastic tubing
Were can I Pick up the plastic tubing @
In LA is anyones guess. They are a lot of plastics R&D companines out in cali so you shouldnt be hard pressed to find some local plastics shop selling the products. I googled my area for some and a fellow floridian and LvC turned me on to another.
If you have the V8 I would try to find a company that can help you custom bend the tubing and add the portholes for the air temp sensor and vacuum lines. I have a heating element that I used to bend my own plastics and have my own solvents to bond pieces. So it might be cheaper to work with them on the design. If they do a good job let them know you will give them some referals.
this is some product that I have been looking at:
http://www.usplastic.com/catalog/pr...e=USPlastic&category_name=54&product_id=16628
https://secure1.nexternal.com/share...BusType=BtoC&Count1=67791163&Count2=984931588
they are offered in different colors as well.
http://www.professionalplastics.com
