throttle body
Jibit
Dearly Departed Friend
Villa Park, IL
working on my '95 and had to remove the intake cause I'm replacing my injectors. I was playing around with the throttle body cause its dirty and I know it has to be cleaned. I noticed when I pull the throttle cable the left valve doesn't open until the cable is pulled completely open (as in at WOT). I know this isn't right but is there a rebuild kit or something for the throttle bodies? I haven't removed it from the car (cause its in the back by the fire wall and my back can't hold out anymore!) but I'm assuming its just a cable? Also need the gasket between it and the intake, I know that's a replacement part. Now I know why I like my Gen 2, everything is easier to get at!
What you describe is normal. Amazingly, the linkage opens them sort of in a sequential manner.
really? I could have sworn that everytime I clean my Gen 2 throttle body that both open at the same time. I didn't think it acted like a carb where the secondary would open when at WOT
I don't know about the Gen2 throttle body. It may be different? But every Gen1 I've seen is like you described.
I had a list of gaskets, but can't seem to find the throttle body gasket number.
if you happen to run across it I'd appreciate it or maybe I'll just give max a call
There were 3 gaskets noted as 'intake' and 2 were in pairs - through the process of elimination, that leaves this part number for the intake to throttle body gasket...
F3LY-9E936-C
$10.12 LIST $
F3LY-9E936-C
$10.12 LIST $
haha! knew you would find it, thanks :Beer
Gen1's use a progressive throttle linkage. If you pull the TB off, you'll see how it works. Supposedly to increase part throttle response.
gen 2's use the same setup as the cobras.
Mike
