stincoln
Hi There
I am attempting to sort out some issues with a '98 LSC that I bought last summer and have just put back on the road after storage.
I've run about a tank of premium through it and had Stabile in the tank for the winter so I'm pretty sure it isn't a case of bad gas.
After about a 100 mile run I stopped for about 15 minutes and then when I attempted to restart it would start but as soon as the RPM's started to drop it would stall for about 15 tries. Pumping the accelerator didn't help and now I have a check engine light. Sorry I can't give codes but when this happened last summer before I put it away I had it in and replaced the #4 COP. It seems to me this might be the same problem again except I notice that when I am at speed and take my foot off the pedal the RPM's take a while to drop. This has me wondering if the IAC or TPS might be the issue...mileage over 200 miles was about 18.5 according to the message centre which also made me wonder if there could a vacuum leak.
Just to whine a bit about Canadian prices for the same brand parts... a Motorcraft IAC is over $100 while I see it for about half that at Rock auto.
Any suggestions about where to start?
Thanks
Des P.
Thanks
Des P.
