Kevin said:I use an amber bulb, with the orange lense removed - looks great!
This pic was only to show the eyebrows, and it was dirty - but you get the idea. Still has an orange look, but only reflected on the chrome. It isn't a solid orange color:
Kevin said:Noah, that's cocaine from a plane the DEA shot down - according to one of the guys from LLSOC.
That photo wasn't taken as a 'beauty' shot, and the car was filthy - but I appreciate the compliment.
I think that to appreciate the clear lense it'd have to be seen in person. I kinda prefer the 'naked' look, where you can see the actual bulb. Regardless, both options look much better than stock.
BTW, just to sway you - the orange light beam effect you get at night from the reflecting off the chrome background is really neat - it'll light up reflective signs 1/4 mile away just like headlights do.
GrayGhost1 said:I have the clear corner lens in mine. It makes a cleaner look than just removing the amber lens.
BIG CELO said:Hey quick question what are those gauges on the driverside you have two of them I'm just curious cause I've never seen that and plus I just purchased my 02 LS8 and I've never seen that
Thanks to Tina above on posting the dual A-pillar gauge pod. It's a gauge pod that is a direct replacement for the A-Pillar. It was specifically designed for the LS. I had mine painted to match the car and I put Faze Water Temp and Faze Oil Pressure gauges in. It's a pretty cool setup.BIG CELO said:Hey quick question what are those gauges on the driverside you have two of them I'm just curious cause I've never seen that and plus I just purchased my 02 LS8 and I've never seen that
GrayGhost1 said:Thanks to Tina above on posting the dual A-pillar gauge pod. It's a gauge pod that is a direct replacement for the A-Pillar. It was specifically designed for the LS. I had mine painted to match the car and I put Faze Water Temp and Faze Oil Pressure gauges in. It's a pretty cool setup.
Ken
