maybe, not sure if it'll be worth it, im thinking of either a tighter headgasket or decking, I would like to see it at 11-1 or higher but not sure how tight these engines are
DISPLACEMENT -----------------------------------------3.9L V-8
BORE----------------------------------------------------3.3858
STROKE-------------------------------------------------3.346
BORE SPACING-------------------------------------------3.858
MAIN JOURNAL DIA.---------------------------------------2.4409
ROD JOURNAL DIA.----------------------------------------2.2047
CON ROD LENGTH (MEAN)---------------------------------6.115
CRANKSHAFT CENTER LINE TO DECK-----------------------8.88
COMPRESSION DISTANCE PISTON PIN TO TOP OF PISTON---1.211
still need the top of piston to bottom of open valve....
