torque converter bolts.
Moes8
Berks County Pa
i am almost done getting my tranny out of the car to replace.
my question is
does anyone have a trick to hold the flywheel/engine from turning while i break the converter nuts loose?
i keep trying to turn them off but the engine wants to rotate,and t of course is trying to rotate counterclockwise which is a no no for engines.
how can i hold it still while i break the nuts loose?
thanks.
ps,pulling a tranny really sucks on a stone driveway.
i really need a paved driveway or better yet,a garage.dang i am sore.
I know what you mean man, I did this job on my back and it sucked!
About holding the engine from turning over, you're going to need another set of hands. Get preferably a 1/2" ratchet and whatever size socket that needs to fit the crank pulley bolt. Have them hold the engine from turning while you undo the T/C bolts one a time.
Good luck...
Last time I did a trans,I actually used Vice Grips right on the flywheel.I put a piece of terry cloth on it and clamped it down.Then I let it rotate towards the side and it stayed there.Then when I moved onto the next bolt I did it again
