Torque specs
KC96LSC
Kansas City
Just wondering what the torque specs are for the tranny and driveshaft? I will be changing my tranny this weekend and have searched and came up with nothing. Is there a place I can go to on the net?
Thanks for any help.
Greg
Section 05-01: Driveshaft 1996 Mark VIII Workshop Manual
SPECIFICATIONS Procedure revision date: 05/18/2000
SPECIFICATIONS
TORQUE SPECIFICATIONS Description Nm Lb-Ft
Fuel Tank Strap Retaining Bolts 29-41 21-30
Fuel Tank Filler Pipe Bolt 2.7-3.7 24-32 (Lb-In)
Sub-Frame Crossmember Bolt 20-30 15-22
Sub-Frame Center Support Member 20-30 15-22
Exhaust Outlet Pipe to Muffler Bolt 28-40 21-29
Muffler Hanger Bolts to Frame Rail 17-23 13-16
Fuel Tank Modification Shield and Pipe Kit Bolt 16-24 12-17
Rear Driveshaft Centering Socket Yoke Bolts 95-130 70-95
and the bell housing is 41-50 lb-ft, straight out of fords tech website
SPECIFICATIONS
You Rock! Thanks chickenviii
Is that page you got the info from a free site? If so, what is the path?
Thanks again,
Greg
no its not public, sorry im a ford tech and i went to ford's tech sight and looked it up like how i look up everything else at work
