Towing an RV with 2004 navigator with stock airbags
Gerardojj
Amarillo
im fixing to buy a 27 foot trailer with a tongue weight of 546 pounds, base weight close to 5000 pounds, has anybody ever towed an rv like this, all tips greatly appreciated, thank you
The wind resistance will kill you more than anything.
I've had a '99 Navi' and currently have a 2010 model that I regularly use to tow an open car trailer with a 4000 lb Mark VIII. The 2010 does a better job with the 6 speed transmission.
The air suspension is where it shines and your tongue load should be just fine. The gross towing weight is close to 8000 lb capacity if I recall correctly so a 5000 lb load won't be bad.
