OK, here's what I did. I removed the plastic cover from the computer connector to access the wires. I located the power wire, pin 26 (brown / white) and the signal wire, pin 17 (gray / white) and connected my analog multi-meter to it. I can now monitor the TPS signal while driving. It reads a little less than 1 volt dc when at idle up to just under 5 vdc when at WOT. Nice and smooth sweep as you increase the throttle position. I still have a bit of a high idle, it feels like the car is still pushing when coming to a stop, could the idle position or the calibration of the TPS be causing me the high idle? I will keep driving it like this until my funky transmission shifting problem resurfaces and then maybe I will catch the TPS giving a strange signal.
