Really, all you need is a 28 spline differential unit.
But while your in there, you should replace all of the bearings, and check all of your end play tolerances.  You can buy a install kit that comes with everything you need, except the mechanic with the tools to set it all up.
but, do you really want to keep 3.07:1 gearing when there are so many different options out there?
