Dern Humpus
I havent done anything to my tranny yet and I'll be running an 80 shot here and there, would an aftermarket tranny cooler be something I should look into? Is anyone else using one? If so, where did you mount it?
Yes, lots.Is anyone else using one?
K*A*B said:deffinetly use a trans cooler , i completely bypassed the stock cooler in the radiator
and actually noticed the engine runs cooler
i mounted mine in front of the condenser and radiator
fossten said:Do you mean that your radiator isn't even hooked up now? I am interested in doing this also but I know nothing about it.
NYC LSC said:No.
There's a stock tranmission "cooler" as part of the radiator. Look for two metal lines on the driver's side of the radiator - those are the transmission lines. What he did was bypassed where it goes into the radiator and just ran it straight to the aftermarket cooler.
I had one on my 87 LSC back when it was still an auto. Very wise investment and I'll have to get around to installing that same cooler into the 95 some time.
