Tranny ??
aggiestckl
doylestown
So my tranny shifts funny at low speeds, but when i go faster it seems to shift way better..
I understand that a new tranny filter? will do the trick
along with that i wanna either do the bauman or j-mod to the tranny, what would you recomend. I have tools, but no lift, just the 3 foot high drive on ramps. What do you recomend? Also I NEED LINKS on a how to or were to buy the baumann kit, also a link to what tranny filter to get?
thanks so much
j-mod vs baumann has been mentioned before. it is really up to you which one you want, but me personally baumann is the way to go.
Its pretty much up to you what kit to pick, they both work really good, if you don't want to worry about going out and buying drill bits and just having everything right there with you, get the Baumann, everythings there. You should be able to do it in your driveway, might be a little more difficult without a lift but still possible. Also don't forget to upgrade your accumulators/springs and if the car isn't an 98 maybe the deeper pan. Good luck!!!
