Trans Help Please
NWOMAKVIII93
OREGON
I just had my 93 mark viii towed to the shop for a pass. side ball joint. No problem as far as I know. I picked the car up and as Iwas driving away NO THIRD GEAR. I thought I had it in 2 but it was in D. Whipped around to the shop to ask what happened of course nobody Knows. It goes through 1---2---then neutral until the speed goes down to wheresecond gear is.Can anybody tell me what happened?:confused:
Your trans is most likely shot! The same thing happened to me and I had it rebuilt. It will cost you around 1200 for a rebuild. You'd be better off buying a used 98+ trans.
:W do you think they took your car out and thrashed it? :shifty:
Ive heard that with the driveshaft in, being towed even while in neutral can mess up your shiz.
They towed it about 10 to 15 miles, I was so discusted, they didn't tie the ball joint so the front wheel was pushing against the bumper, I thought the exhaust tips were going to scrape the ground. It was in neutral. Do you think the tow did it?
10-15 miles is pretty long distance, I've only had a few cars towed in my day(knock on wood). I seem to remember many of people telling me this over the years.
