trans"O"ring
JRMARK8
wixom/bx,nyc
How can i replace transmission filler tube O ring because mine is leaking and do you have pics. THANKS
The bolt that holds the tube is on the back of the head about midway up. I took my car to a tranny shop for them to change it as I do not have a lift nore a 3 foot extension. It took all of 20 minutes & $20.00 for two guys to change the o-ring out, as it took 4 hands to hold the extension and swivel socket on the bolt. To re-install the bolt they used grease to insert and get the bolt started. Easy :)
