Well my friends marks transmission slips really badly. But not until it gets hot, when he starts it up it drives fine for a while, but eventually starts slipping like crazy. What could be wrong?
I've had problems with my 94 Mk VIII trans too. Would slip in first. Fluid was low I topped it up now its ok. Dipstick tube o-ring needs replacing. I drove the car in the rain the other day and had problems which seem like TV cable problems on Mk VII. RPM's increase on top gear for no reason and car slows down. Never had the problem before and took it out a few days later on dry roads problem is gone.
RT
I thought maybe some transmission control connectors or ??? got wet in the rain and affected trans shifting?? Trans still working fine...and sometimes I run it hard. Who knows maybe it'll blow up next trip. I'm going to change oil + 1-2 accumulator later if it survives.
RT
i just had a total rebuild, and in the rain last week it started slipping too. the trans shop said it was the MLSP? try that...i'm replacing mine this weekend...hopefully it will work!
