Trans Problems
87lsc
Hawley, PA
where sure I begin!!! I picked up the 88 about 2 weeks ago and drove it for 188 miles just to and from work. You know just to get everything going again but on the way home I notices that I was running at a higher RPM then I should be, when trying to go up a small incline she was not gaining any spped but just reving and then grabed a gear. When I turned on the block that was it could smell the Tran fluid!!!!!!!! Went to put in in Reverse and it jerks. So how I have to find a shop that will not bend me over to get it repaired.........:( :( :runaway: :soapbox: :mad:
Check the TV bushing. Your tranny is probably dying at this point, but it's an easy fix for the next tranny.
Staff online
