livinglegend8119
I have a 99 lincoln continental with 167,000 miles on it, bought it a couple of months ago and is not sure if the tranney was ever serviced. The transmission is leaking fluid that drips on the converter but when i check the fluid it reads full. I am assuming it only leaks when the car is at normal run temp. The question is where could it be leaking from ? I am pretty sure this is the reason y my conti is shifting hard especially after being warmed up.
