Transmission won't engage in D5, but will in SST
ap1975
Haymarket
Help please...
2001 Lincoln LS V8. After coming to a stop yesterday When I tried to go all i heard was the engine winding and I wasn't moving at all. After sitting for a few minutes I tried the SST and it worked fine. So now the car only moves using the SST. Does anybody know why this would happen??? Any help would be appreciated.
Help please...
Sounds like a broken shifter. The shifter controls the transmission electronically. I had a diode go bad years ago and I couldn't engage D4. There could also be a small piece of dirt/lint/gunk on the contacts.
So is this something I can fix or do I have to take it to the stealership???
As long as it's the shifter you should be able to do it. I would have an official (dealer) diagnosis, though.
When you put it in drive, does it display D5 or D4 on the instrument panel?
I would guess it's a transmission or computer problem then, not the shifter itself. But who knows!
