85 TC Signature
3.0/ 65K total miles
I had an unpleasant surprise yesterday noon when I discovered the TC wasn’t shifting. In the usual Overdrive position, the engine just kept reving higher; I took it up to 20 before I decided it wasn’t
going to shift.
1) can manually shift it into Drive & 2nd without anything happening.
2) If I go down to 1st, I can feel the engine load, so maybe it is in 2nd
3) aside from the one forward gear, neutral and reverse work.
4) I checked the trans fluid and it is a translucent ruby red and full.
5) the antenna mast also works fine ; )
Some years back… ok, a lot of years back, I had a similar problem with a Dodge Coronet and had to drive it a week with one gear before I could get it in to the shop. The mechanic called, saying a rubber hose had come loose on the tranny and charged me $5 to replace it.
Are there any simple things I could check, before taking my TC to a shop? Preferably under $5.
going to shift.
