Elessee, it is rockin reply to my post, no doubt. I have had that motor on the bench (a small table in front of the TV in my apartment). I tried manually turning when I felt it was catching but it turns out it was the wrong direction and it started to crack the plastic housing. Note of caution to all.
I will try again to crack this nut and at least post which way to turn the worm so you are trying to get the latch to go down and not screw into itself. I don’t have it in front of me because I live in a city where an open trunk is the devil’s plaything. At any rate, that was the only way that a turn was catching. I tried the disassembly, but the first step is star headed screws of which I do not have the tools.
I’m in Miami and if anyone knows of Mark VII or any Lincolns in salvage I would love to here about it. I can’t find a single one. People drive like a disaster here and there are plenty of junkers, but just haven’t seen a single Lincoln.
Its interesting that you also had a white hot motor and that it still worked after it cooled. First thing I did was take out the motor shaft and it wasn’t mated as you describe so I think I have some damage. I probably did more damage cranking it the wrong way. I’m not going to try to hotwire it at this point although your post is dynamite in a general help sense. I have really benefitted in the past from posts like this and cheers to you. I will certainly let you know the results of having the motor on the bench, but I need to do this in the morning for security.
My car doesn't use those star things.. ('88Mk7) These are regular hex-headed screws holding it to the trunk wall.
I've picked up the "star" drivers along the way... from tiny to small and large. They're not expensive at the cheapo-tool stores (google harbor freight tools) and they come in handy for some more mundane things. You'd need one to remove seat belts, for instance.
If the motor pulled out, the teeth on the plastic gear may be destroyed.
As far as getting parts from auto wreckers, google "your state" and auto wreckers. These guys mostly cooperate among themselves.. some join associations.. and they find and ship parts back and forth. Then the customer goes to a local one and picks them up.
"FADRA - Florida Auto Dismantlers & Recyclers Association" comes up first on my browser search..
I'd suggest you try and order the entire assembly. IMHO them asking for $50 (with some kinda return policy or warranty) is about right.. although I'm such a cheapskate i'd still try to get a better deal..
As for testing the motor, I was a bit nervous about trying it.. but then I was sure was happy when the motor spun.
My harness connector has
one Red and
two Black wires. Red-black-black
Look at where the motor plugs into that connector. Mark the red connector tab on the motor with a scratch or a pen/crayon.
Put 12V Positive on the red and 12V Negative on one of the black. Then put Negative on the
other black (to spin it the other way).
And yeah.. it's a plastic housing and it's brittle.. It's degraded by age and grease. So if anyone is getting into this, brute force only makes things worse.. finesse is the preferred method.
Good luck with it.. keep us updated.
