Trying to solve front end issues
93mark8rules
Paramus
So I made the mistake of buying the Ebay front end kit, and Moog Strut Rod bushings. 12K Miles later, Im on my second set of strut rod bushings, and there is no play in my front end but now 2 different shops cant get my camber right in the front end. I noticed some rubber coming out of the Lower control arm to frame, and shock bushings. So Im going to go buy 2 new Moog Lower control arms, and also I found a set of original Ford strut rod bushings.
Dilemma 1: I saved my original bushings and hardware, they werent that bad but I saw they were starting to crack so I thought Id replace them. I was looking at some of the write ups online and I think my hardware is a different design. My strut rods have only one spacer with a step at the end and then the washer at the end with the nut fits on to that step. Is this an early design or something? Will I have any trouble using them with the new bushings?
Dilemma 2: They said I needed a camber kit. I also want to sensor lower the car, so maybe it would be worth buying one. Does anyone know what the stock range of adjustment was? I found a kit that goes up to 1 1/8 degrees or another that goes up to 1 1/4 degrees. The 1 1/4 is almost double the price, so I wanted to make sure that it does give me more range than stock.
Dilemma 3: When I replaced everything In the front end ,I never changed the drivers side upper control arm. If I doing it all again I might as well just do it. I bought a swivel, ratchet, wrench, and I regular racthet wrench, and I wasnt able to get the bolt loose is there another trick for getting the bolts out besides pulling the master cylinder.
Last question does anyone have torque specs for the arms, and strut rod bushings?
Thank you SPREE, you just solved it for me. I must have ground the front spacer off to get the washer out....
Do you or anyone else know where to get new spacers?
After days of searching, I decided to try searching for Thunderbird Strut Rod Spacers and came across this site http://tbscshop.com/epages/91de4b5d-28e9-49ef-a784-99b6b5b3a442.sf/en_US/?ObjectPath=/Shops/91de4b5d-28e9-49ef-a784-99b6b5b3a442/Products/ST0035
It looks like he has everything. I wish I found his site earlier I already ordered the strut rod bushings from Tasca. So once direct deposit kicks in tonight I am going to order just the spacers and washers. But either way Im excited to fix my car!!! Plus now you guys have a link to use and stop buying these horrible Moog Parts!
Considering my bushings are good on the drivers side upper control arm, has anyone tried using one of those ball joint presses you can rent for free and just changing the actual ball joint? Seems much easier, just never done it. Mine isnt bad YET but the boot is torn and the car has 177k miles on it.
