Turning off air ride light
john1978
Ballston Spa
Hey I swapped out my air ride a few months ago and just got around to turning the lights off on the dash.I am trying to grund that on wire cause it controls the power steering anyone else do this and if so where did you ground it at.I tried the seat belt mount stud to no avail.Thanks
there is a green wire on the test connector for the a/s computer. that I believe is the wire to ground. can ground to just about any avail screw in area.
I am thinking your grounding the wrong wire.
your power steering is stiff?? is that the problem with it? the a/s computer has steering inputs to it (rate of turn of wheel mostly), but no effect on the actual assist rate (to the best of my knowledge). if the wheel is tough to turn, you lost the input from the speed sensor (VSS) to the vaps (variable assist power steering) in all likely hood. I had that problem when my VSS crapped
yeah but i didn't lose the power steering until i spliced the wires according to strutmaster instructions.I'm just looking for a good ground other people have had luck with.
