two easy questions
SilverLS
Winter Park (near Orlando)
OK SO I PUT NEW TIRE ON THE LS i WENT WITH A 225/60/16 AND NOW I WONDER DO I NEED TO PUT THE TIRE PRESSURE AT 40 ALL THE WAY AROUND TIRES SAY 40-60 BUIT THE LS SAYS 29/30 SO WHAT TO DO????
ALSO I SEARCHED AND CANT FIND THE HOW TO INSTALL THE ANGLE EYES .....I KNOW THERE WAS IN DEPTH HOW TO....SO IF ANYONE HAS IT PLEASE LET ME KNOW
DAMN THERE ARE SOME FUNNY A$$ COMERCIALS ON LOL LOVE THE "MAGIC REFIDGERATOR"
LOL
THANKS GUYS:)
Did you put one new tire on, or a new set... can't tell from the way you type. If you put new tires on your car, then go with what the tire recommends... staying in between the high and low maximum.
If you bought one new tire that is different from what is on the other three wheels, then that could be a problem. Tires react differently between manufacturers at the same psi... and it's never a wise idea to have different tires on the car or different psi's on all the tires. So, the only thing to recommend is to have the same tires on all corners with the same psi in them.
You didn't search enough my young Padawan Learner...
http://www.lincolndde.com/lincolnfinal.doc
OK first off YEs I still running the tint....thanks
I put on 4 new tire 225/60/16.....So I need to run 40 psi......
Thanks for the link ......I searched and couldnt find the install I found about of other stuff.....
