Two strange things.
J3FF
Lexington
Ok so I was backing up ot of a parking space today and as soon as I put the car in drive the "check advance track" came on and the car didnt react to hardly any throttle position. So I pull off the road a couple miles later and put the car in park and shut it off. I start it back up and the car is fine so I pull off again at a gas station and put it in park and as soon as I open my door the car pops out of gear, rolls about 3 inches, then goes back into gear. I've been putting the handbrake on just to be safe. Has anyone had either of these things happen to them?
Sounds electrical - but I'd check the mechanical aspect of the Trans Gear Selecter and make sure nothing is binding...
I think if you can get some info on that Advance Track you'll find all your problems right there...sorry man - free bump!
Well today I shifted down to 2nd in my neighborhood and heard a pop, and then I tried it again and heard the same thing, this might be bad.
any luck on this issue, My wife was driving yesterday and the same thing happened "check advance track" came on in the message center, but there was none of the other issues that you stated.
Edit: Disregard, I found my answer in another thread.
