Dern Humpus said:
Who has them? Are they worth it? Brands? Dyno results?
Steeda, ASP, March, Summit to name a few. They should all produce similar results. Most are around 25% underdriven at the crank, but then the alt and water pump pulleys are designed to give some back.
I know Geno fimly believes in just a crank pulley. I see it as probably effective by itself.
They should produce near or around 10hp to the rear tires in my opinion.
I have a 3 pc. ASP set on my 91MarkVII and they definately made power. Could feel it in the acceleration, it revved more freely, coasted better to my surprize I could feel less drag and even the tranny shifted better without the drag. Also a noticable increase in fuel economy.
I also have a March set on a older 302 of mine, I put them on and converted to an electric fan at the same time, picked up very noticable power on that one considering it was lugging a seven blade solid mounted fan before the switch.
I'm going to be putting a set on the MarkVIII pretty soon so I'm interested in the opinions of them on the MarkVIII. I'm currently leaning to just the crank pulley as I'm concidering an electric water pump down the road a little and so that would kind of defeat the purpose of the one pulley. I also have considered if just doing the electric pump intead would produce better results anyway as most of the drag is there. Both would probably be the best.
